Specifies the server location for the DHCP bindings storage file. The uploads can be made to any TFTP server regardless of the virtual router that it is present in.
| ip_address | Specifies the IP address location for the bindings storage file. |
| hostname | Specifies the hostname of the server. |
| vr-name | Specifies the virtual router name. |
| none | Using no option unconfigures the server. |
N/A.
This commands allows you to specify where you want to store the DHCP storage file that you created with the command configure ip-security dhcp-bindings storage filename name.
Using the command with no option unconfigures the server.The following command configures storage to the primary server 10.1.1.14:
configure ip-security dhcp-bindings storage location server primary 10.1.1.14 vr "VR-Default" tftp
The following example unconfigures the primary server:
